I am trying to import a pdf plan to sketchup and when I go to import the document it is not showing to attach it.
In the past I would convert PDF to DWG however saw the below guidelines on HowtoSketchup:
Step-by-Step Guide to Importing PDFs in SketchUp
Let’s look at some methods for importing PDFs into SketchUp, depending on the version you’re using.
Method 1: Using SketchUp Pro’s Built-in Import Function
For users of SketchUp Pro (available on both Windows and macOS), there’s a built-in feature for importing PDF files directly into your project. Here’s how:
Open Your Project: Start by opening the SketchUp file you’re working on.
Navigate to Import Options: Go to File > Import, and select the PDF file type from the dropdown menu.
Adjust Settings: Select import options to set the resolution and scaling as needed.
Place the PDF: Click to position the imported PDF on your SketchUp model.
Align and Scale the PDF: Use the Tape Measure or Scale tool to match the PDF dimensions to your model accurately.
The above is not working even though I have the PRO package.
What version of SketchUp? Your profile says 2019. Are you still using that? Are you still using Mac?
What part of that isn’t working? What happens when you do try to import the PDF into SketchUp? Note that PDF import is only available on Mac and the PDF will come in as an image, not as vector line work as you would get with converting to dxf or dwg and importing that.
FWIW, if the PDF contains vector linework and you want a .dxf from it, you could use Inkscape to create that line work. Inkscape is a free application and is useful for a number of things.
