I have a speaker stand that I built. I want to show all of the components. It has a wood top and bottom, 3" pvc pipe, all thread rod going from top to bottow, nuts for all thread are recessed and I have a steel cylinder for ballast that slides over the all thread. Will sketchup 2015 allow me to do this. I can add a picture if needed.
That certainly sounds like it is quite easy to do in SketchUp. Don’t model the threads in the rod, though, if necessary, use a texture instead.
Anssi
I haven’t used sketchup that much. Is there a tutorial.
thanks
Mike
http://www.harwoodpodcast.com/
Then search for “SketchUp”
There are tutorials that take you through every tool.
You don’t have to search. SU is listed third in the “Technology” menu. Good luck.
