Hi. My name is David and i need help with my 3D model.
I am included in my country national 3D modeling competition in Prague.
Basicly i need to 3D print my lamborginy tire, but when i try tu convert it into Prusha slicer, it messes up and i can´t print it.
Would there be someone here who would be so kind as to help me with this?
It´s my first more complexed model, so sorry about that… koloroz.skp (2.4 MB)
This is project without components
and this is project with it: kolo-lamborginy.skp (1.6 MB)
You also have a number of reversed faces (shown as blue) which need to be corrected. The face orientation tells the slicer which side of the face is toward the print media and which side is to air. White front faces are always towards the air.
Those red lines in John’s screenshot are surface borders; the edges around holes in the surface.
As John indicated, for the kind of detail you want in your model you would do better to do the modeling with Units set to Meters. Treat millimeters as meters. There’s a lot of issues with your model. I expect you would be time ahead to start over and model it cleanly.
If you spend some time at The Learning Center, you will learn how to use the tools to get what you want. (interactive tutorials) Also, go to The SketchUp YouTube Channel and pay attention to the Square One series. Both are sponsored by the SketchUp Crew and well worth the time spent there.
Not from just that screenshot. Probably duplicate faces or faces that aren’t actually attached to the rest of the geometry. As I wrote before, you would do better to start over after learning how to use SketchUp correctly.
