I’ve used Sketchup for quite a while, but not very seriously. Unfortunately I’m not 100% sure how to even describe what I’m trying to do.
I’m trying to make a model of a building I saw so I can understand it better. It’s a reciprocal roof structure made of roundwood timbers. So I’m modeling the basic elements as tubes 12" in diameter. The timbers lay on top of each other at 30 degree angles on a horizontal plane (20 degrees vertical), creating an interlocking circle. That part I’ve got more or less figured out:
Now that I’ve got that part put together I realize I’d like the individual beams to be shorter. Specifically I’d like them to end at the top with a 30 degree angle on a horizontal plane that is in vertical plane with the outer edge of the beam below. Here is a photo of a similar building to show what I’m trying to accomplish - https://timberhomesllc.com/wp-content/uploads/2015/11/15629729_1569060.jpeg
So I guess there are two parts to this. 1: How do I use the outer boundary of one object to define a plane for slicing another object; 2: How do I make a defined, angled end on a tube object. Seems relatively straightforward for rectangles, but round surface hurt my brain.
Sorry if this is obvious, I feel like these are pretty basic skills that I’ve just never bothered to figure out and I’m not precisely sure how to search for them.
