I want to select and resize that, but I can’t please help
Probably faster to make it again the right size.
I made it right but when I convert it to a pipe the diameter changes
How did you convert it to a pipe?
Can I suggest you provide information. Explain what you do and what you were expecting… share the file so people here can look and offer help. One sentence and a screenshot is rarely enough to get help on a modeling issue.
This is my problem
well yeah, you’re only selecting one end of the pipe and scaling it. the rest won’t scale.
if you want to select your whole pipe, triple click on it to select it all.
but Dave in the message you linked doesn’t use the scale tool anyway…
I want to change the end of the pipe diameter like a cone pipe
Thats what I see happening in your video. So it must be something else..
Try cleaning up the selection. You are selecting the face and a couple of lines connected to the pipe and another below… EVERYTHING that is selected will be included in the rescaling.
I understood my problem thanks, I wrongly slelected another parts
Yes I want to do this
Note that the thickness also scales… so if you need this to be precise you will have to look at alternative ways to do this.
Thanks bro
If you want to reproduce what is done in the piping industry, it is best to use two separate fittings, an elbow and a reducer.
Join the two fittings together as a pipe fitter would do. You will see a series of edges all around the junction. This is correct since, in real life, the two fittings will be welded.
