I have welded all the lines that form the spiral
that I created along a central cross divided into equals
and then changing the path along the left bottom of the cross
I tried just to pull but then the entire spiral comes along
I want it to pull like a cone along the path
How should I go about it?
Obviously my thinking is wrong
Thanks
Hello thank you
I think it may be correct but I can’t tell as the angle doesn’t show in an angle that shows the spiral from
the smallest to the biggest side.
What I am interested in, is the method you used to pull the spiral?
Thank you.
I didn’t pull the spiral. You can’t just pull the end like you could if it was a piece of wire. I used an old extension called Helix Along Curve to draw it.
Hello
I thought I have tried to pull it along like a wire but it was the complete spiral that moved along .
I don’t have that extension. If you don’t mind me asking.
Do you mind sharing the skp file back, so I could look from other angles and explore?
Thank you very much
