Hi together
I have the free version and I have planned a survival Truck in 3D with sketch up. Now I want to print the drawinings with the measurements (e.g 200cm)
Have you added the dimensions to the model? Once you do that you should be able to export images to print with the different views you want to show. You could set up scenes in the model and then just go through the scenes one at a time and export the images showing the model as you wish.
Or you can hit Print.
thanks! No I have not added Dimensions. How can I do it? I would need those measurements as indicated in red - can I select the most relevant ones as I have too many objects
Use the Dimension tool to add dimensions between the points you click on. The tool is in with the Tape Measure tool.
