I would like to make a script which makes the same as ISO button. Do you have any suggestions?
br.
Marcin
br.
Marcin
Sketchup.active_model.active_view.camera.perspective = false
http://www.sketchup.com/intl/en/developer/docs/ourdoc/camera#perspective=
OK, it’s turn perspective into isometric view, but dosn’t change same view. Dosn’t set an eye of camera (position, angle and distance) the same way as makes it button ISO.
Use
Sketchup.send_action("viewIso:")
then
OK, it’s works.
Second part of my job is make ISO view on DC always from the same side. DC has its own axies, and I would like make the ISO view always from the same side (same axies) idependently that DC is roteted in the model. My DC has face, sides, top and bottom. I need all of them (DC) see the same way (from face).
Perhaps make 4 copies of the DC [***one for each view?].
Rotate three of them through 90/180/270 degrees [about their bounds.center].
Put each on layers named 0/90/180/270 and make 4 scene-tabs named the same - each one with only that one matching layer set ‘visible’.
Now use the send_action
and camera.perspective
code snippets on each scene-tab’s camera in turn…
***Obviously if you have say 6 desired views rotate through different angles, make more scenes etc…
