How to make a bulb flash
hello,
I am looking for and extension that will allow me to light up bulbs and have them flash
also moving colors along lines
Is this possible
How are you using the model? What sort of output?
There’s no way to make objects flash within the model space but you could use several copies of the object painted different colors and with different tags. Then control which object is visible in each scene.
Quick example. Here I’ve got three cylinders each with a different color. First, with them separated so you can see what’s going on. Watch the Tags panel on the right.
colors1
And here with the cylinders in the same location.
colors2
