So this is the scenario, is there a plugin that can join 2 edges of different meshes together in one and make it 1 continuing mesh. Like the vertex tools merge point option but in vertex tool you can only join 1 point at a time. So this is what i want, a plugin that let me select my 2 mesh points and when i press the button it automatically joins all of them making a bridge between 2 points and one more thing, let’s say edge 1 and 2 both has 8 8 points, I don’t want to join those 16 points into 1 but rather make a connection between those 16 points. sorry for bad english and thanks in advance.
Not really sure what you mean in the second half of your post, but maybe Sandbox tools or Curviloft (and there are others) could generate the missing area. IIRC you would need to select the perimeter of what you want to mesh in order the use the plugin.
Vertex Tools > Merge Close Vertices
@mihai.s ■■■■ i didn’t knew we can join all points at same time😅, thanks
You can also use the vertex move tool to easily manually move things to close the gap.
