Under some situations , we need very large calculation , for example the accurate calculation of shading points in a very large plane.
The program seems to be crashed when running, is it a method which can watch the calculation progress if the calculation time is more than 30 seconds? It will be helpful for the user who uses our plugin.
I think your post is easier to read of you remove the formatting.
This is called “Not Responding” or “Ghost mode”.
You could try every so often between your calculations, to call view.invalidate or UI.refresh_inspectors or UI.refresh_toolbars.
For speeding up calculations the only thing you can do is implement a Ruby C extension.
