I did notice that, I guess that the original developers did drove them selfs in a kind of deadlock; continue with blisters and bandage or rewrite a massive piece of code. Happens often, also with Lotus Notes and Formula, they also did have to rewrite that. Maybe SU has to rewrite the events for the model engine.
Anyway, I did try this to get your idea working, but it crashes.
I did put some messageboxes in there to look at the call order. I notice that when I wait to dismiss the messagebox with ābuild_menu_item - menu not loaded yet exitā it crashes directly after, but if I am quick I get also the to see the " build_menu_item - exit" message. But then it crashed direclty after that. My guess is that it happens because of removing the observer. If I remove that line, then it so far works, but if that is the purposeā¦
( BTW, is there a kind of keyword like LINE or FILE but for a def or module to shoe in what for def the code is executed? )
module RvAmerongen
module TemplateSetManager
extend self
NEW_FROM_TEMPLATE ||= "New ..."
@@menu_loaded = false unless defined?(@@menu_loaded)
@@manager_open = false unless defined?(@@manager_open)
@@manager_menu ||= MF_ENABLED
#{# AppObserver callbacks
def expectsStartupModelNotifications
UI.messagebox(__FILE__ + " expectsStartupModelNotifications")
return true
end
def onNewModel(model)
UI.messagebox(__FILE__ + " onNewModel")
build_menu_item()
end
def onOpenModel(model)
UI.messagebox(__FILE__ + " onOpenModel")
build_menu_item()
end
def build_menu_item
UI.messagebox(__FILE__ + " build_menu_item")
unless @@menu_loaded
UI.messagebox(__FILE__ + " build_menu_item - menu not loaded yet")
menu = UI.menu("File")
mItem = menu.add_item(NEW_FROM_TEMPLATE,1) { open_manager() }
menu.set_validation_proc(mItem) { @@manager_menu }
# Don't load the menu item again ...
@@menu_loaded = true
# We are now done with the AppObserver ...
Sketchup.remove_observer(self)
UI.messagebox(__FILE__ + " build_menu_item - menu not loaded yet exit")
end #### IT CRASHES AROUND HERE
UI.messagebox(__FILE__ + " build_menu_item - exit")
end
def get_templates
# build list of templates
# Get them ...
UI.messagebox(__FILE__ + " get_templates")
tdir = Sketchup.get_resource_path("Templates")
file_list = Dir.chdir(tdir) { Dir["*.skp"] }
# List them ...
UI.messagebox(file_list.join("\n"), MB_MULTILINE, "Templates")
# Current one ( full path )...
previous = File.basename(Sketchup.template)
# Pick one ...
result = UI.inputbox(
['Choose template file '],
[ File.basename(previous) ],
[file_list.join('|')],
'Pick one ...'
end
def open_manager
@@manager_menu = MF_GRAYED
UI.messagebox(__FILE__ + " open_manager")
# create the WebDialog here...
get_templates()
@@manager_open = true
end
def on_close_manager
UI.messagebox(__FILE__ + " on_close_manager")
@@manager_menu = MF_ENABLED
end
UI.messagebox(__FILE__ + " menu_loaded not yet")
# Always enable menu item, How ???
# By using an AppObserver object, this module will do.
Sketchup.add_observer(self) # (self is this module)
end
end
end
About puts, I knew, but then the only way I (know) can use the console is to disable MyPlugin open the console and then enable MyPlugin, but then the load order with other pluginās are different. So the ui.message is easy when directly from the start with the plugiin always enabled.
Also because of the pause, by not quickly dismissing the dialog, I notice the time needed by the observer.
Hmm, maybe there is SU.command to open the console. Bu that is for tomorrow.
Is there a serious book about the inās and outās of Skechtup and Layout ( with development in mind )? Not about ruby but specific SU. I did see happily that Layout can accept plugins, but very less information or samples?
I want to do the same for Layout. So far as I can see I can load the template names bij using a hardcoded path.
Anyway, when I do have a path to a LO template, it doesnāt load.
If I save a template.layout I canāt, read it wonāt, load in Layout.
This is the simplest code and copied from the docs.
doc2 = Layout::Document.new("/Users/dev/Library/Application Support/SketchUp 2018/LayOut/Templates/A1 Landscape.layout")
# doesn't work, I do get a ref pointer in the console
tfile = "/Users/anubis/Desktop/Untitled.layout"
puts("#{__method__} - Layout start loading")
doc = Layout::Document.open(tfile)
# nothing get opened. I do get a ref pointer in the console
definitions = doc.auto_text_definitions
definitions.each { |auto_text|
puts("tag : #{auto_text.name}")
puts("name : #{auto_text.tag}")
#definitions.remove(auto_text) unless auto_text.mandatory?
puts("#{__method__} - Layout loading done??")
What do I wrong? I canāt find a doc.show command.
Since I donāt have your files, I canāt say why your attempts to open it in the API donāt work. They work for me with my files. Maybe the problem is with what you expect from the methods #new and #open? These create a Layout::Document object instance within the current SketchUp Ruby session and provide access to it for manipulation. It is somewhat like the external SketchUp C SDK except embedded in the SketchUp Ruby API. They do not launch LayOut or open the file in LayOut itself. There is not (yet) any API method to launch LayOut and tell it to open a Document.
