How to find occlusion in vray for sketchup pro 2019?
I recall finding it easy before, however looking at tutorials Indirect illumination is where it at, this is nothing i find in my version of vray though - Anyone knows how to go about this? thanks,
Vray doesnât really like doing AO any more - if you listen to their CG Garage podcast in the title song it actually says âAmbient Occlusion is passeâ!
But you can still find the setting squirrelled away under the options in the Global Illumination settings (you have ensure that the settings are in Advanced Settings mode to see it. It is also only available as an option for a CPU render.
If you are after a separated AO pass however, you need to add an âExtra Textureâ render element to your stack - in the texture option for the element set the texture slot to a âDirtâ texture, you then have plenty of control over Occlusion settings.
Hope this helps
