I want to export sketchup model in obj format, but not the whole model. I want to export the part which is
located above the ground plane(red-green plane).
I have tried to create a section plane on the ground plane, but it didn’t the trick because after setting section plane and exporting the model I could see that the whole model was exported.
Is there a way to achieve this, without changing the model much ?
Here is what I’ve tried
model = Sketchup.active_model
entities = model.entities
origin = model.axes.origin
if origin.z!=0
sp = entities.add_section_plane([0, 0, origin.z], [0, 0, origin.z])
#sp = entities.add_section_plane([xaxis, yaxis, zaxis], [xaxis+10, yaxis+10, zaxis])
sp.activate
sp
end
status = model.export(outpath, true)
