How to create a geometrical 3d wall tile
Hello,
I need some smart trick to go around the fact, that SketchUp doesn’t recognize point movement. I tried already with creating a line on top of the point, but the problem is that SketchUp compensates with creating unnecessary surfaces. How to create these 3d wall tiles in SketchUp?
Hello, what do you mean sketchup doesn’t recognize point movement ?
TRIANGLES
make group out of your triangles, extrude them
select the move tool and move points
if at some point you have something else than a triangle, you can instersect with a rotated plane (or use solid tools with a solid instead of the plane) :
intersect
Creating geometrical 3D tiles with extensions
That’s just what I needed. Thank you guys
