Trying to create 3D Map of the race course.
I need exact model with exact heights and exact borders, like on screen
Ho to make it with the simplest way? Thank you!
Coordinates
Coordinates
What do you actually need to model, topography, infrastructure, assets? What is the end purpose for your model?You could engage surveyors with lidar. The engineers who did the job originally (I think it’s not that old) will have all the survey information. Without this “on the ground” information what ever you do won’t be exact. To get approximate distances you could use the measuring devices in Google Earth.
I need a model of this track with heights and depth to see slopes and climbs (they are very insignificant).
I have enough information from Google Earth
Have you tried if what you get from the Geolocation feature in SketchUp is enough for your needs? It gives you the 3D terrain based on the service provider’s database.
Thank you very much for your help!
Hello, Community.
It is possible to push/pull landscape?
I need to pull this map to create flat base.
How ot make it? I have Slicer5, but i can’t mak it
Is there some kind of detailed course on creating landscape in Sketchup (maybe paid) or there is more suitable software?
This is SketchUp’s official course on Landscape / Site Design. Specific to your needs is Course 2, Terrain & Grading.
https://learn.sketchup.com/track/sketchup-landscape-site-design
Thank you, i will research this course. But i need something deep, i think. I need to to work with geo-terrain model and i really stuck with it. Few years ago i have made quality interiors and object modeling, but today i need to create terrain with geolocation including elevation (simple) and i can’t even create quality terrain, can’t insert some objects, roads…etc. into this terrain. Surface has a lot of roughnes, andit alway “torn” in some places…
This depends on what you understand exactly by “quality terrain” - you can use the TopoShaper plugin - https://www.youtube.com/results?search_query=toposhaper+sketchup
You could use DropGC or Skatter
Use Artisan
For more advanced techniques, you can follow tutorials for other programs like Blender, 3DS Max, Mudbox, 3D Coat, Gaea, etc … and then, the terrains created can be imported into SketchUp, using Transmutr, Skimp or Meshlab.
A lot of thanks for your detailed answer. I’ll imediatly begin to leran this materia!l
thanks
You can try cadmapper.com, which will provide you with approximate terrain. If you tell us exactly what you intend to do, we can make better suggestions.cadmapper-cheltenham-england-gb.skp (1.5 MB)
This is almost what i need!
But a little of map is missed. I’m trying to create the same on cadmapper.com but i ca’nt receive this result with elevation. buildings roads (please see srceen what i have)… How did you get it?
And how i can draw it with google map texture to draw all elements like roads, hurdles, trees and etc…?
thank you!
In cadmapper.com, Road Geometry, set “mesh surfaces” 16, 8 , 8 , 8… Change color of layers and set “color by layer.”
The easiest way to add the smallest details (streets, paths, trees and buildings …) is to draw over the google image in Autocad.
Always use tree blocks in Autocad. Because they will become components in Sketchup.
Draw the edges of the paths so that in Sketchup you can do FACES. With faces, use sandbox “drape” command to project the paths on the terrain surface.
I’ve done it a few times and the result has always been good.
