I got a face’s area num : a = 136707.9693742, then I used Sketchup.format_area(a) got 88.2 m².
My question is, is there any method like to_m, to_mm that can directly conver the num 136707.9693742 to 88.2 without the m².
Anyone would help me?
If you want to calculate the m2 of a Face that is not part of a group or component, you can calculate by dividing the face area by the factor to convert it to m2.
sel_face = Sketchup.active_model.selection[0]
factor_m2 = 1550
area_m2 = sel_face.area / factor_m2
puts area_m2
To use / test the above script, select 1 face in the model and then run this script with the Ruby Console.The output contains the m2 of the selected Face.
Thank you very much, you solved my problem!
More sophisticated and more general code snippet, just for fun…: ![]()
(Works in SketchUp 2020.0 or newer)
The result will depend what is in the current Model Info Unit settings and the regional settings
def area_text
case Sketchup.active_model.options["UnitsOptions"]["AreaUnit"]
when Length::SquareInches
return " in²"
when Length::SquareFeet
return " ft²"
when Length::SquareMillimeter
return " mm²"
when Length::SquareCentimeter
return " cm²"
when Length::SquareMeter
return " m²"
when Length::SquareYard
return " yd²"
else
return ""
end
end
def area_no_unit_str(number)
Sketchup.format_area(number).sub(area_text, "")
end
def area_no_unit_float(number)
dec_sep = Sketchup::RegionalSettings.decimal_separator
area_no_unit_str(number).tr(dec_sep,".").to_f
end
puts area_no_unit_str(136707.9693742) #-> 88,199
puts area_no_unit_float(136707.9693742) #-> 88.199
References:
Length
Yes (to specifically answer your question.)
Sketchup.format_area(a).to_f
#=> 88.2
… or …
a.to_m.to_m
#=> 88.19851352145888
To round …
a.to_m.to_m.round(1)
#=> 88.2
See what methods the API adds to the Numeric classes:
… in addition to the Ruby core base Numeric methods (such as #round )…
I am from a foreign country
, so this one for me returns:
#=> 88.0
I suggest:
Sketchup.format_area(a).tr(dec_sep, ".").to_f
… which is why I gave alternatives. ![]()
Do you want the string (with no unit) or a float and do you want it to always be square meters or follow the model unit display settings? What do you want to use it for?
Often it’s good to stick to the internal SketchUp units as long as possible, and format only when printing the value to the user, but in such case there isn’t much reason to strip the unit.
That is what I want!
thank you very much!
