Hi
This is really bugging me.
I want to create a point using:
pt = Geom::Point3d.new(1.m,1.m,1.m)
and then write the value to a string WITHOUT the metres “m”
pt.x.to_m.to_s
Is this really the neatest way to do this?
Hi
pt.x.to_m.to_s
First of all, (for general info,) there are some nifty module methods
for creating numeric strings that use the user’s current model units.
Sketchup::format_angle()Sketchup::format_area()Sketchup::format_degrees()Sketchup::format_length()No, your way means you must interrogate the model options to determine what the user’s model units are and adapt (as in a complex branching statement with multiple conditional expressions.)
This way you do not:
pt.x.to_s.to_f.to_s
The first to_s is the API’s Length class method that returns a numeric string in the user’s current model units WITH the unit symbol. The to_f then converts back to a number without regard to model units (so basically just removes any unit symbol,) and the last to_s is the Ruby core method for the Float class.
What I’d do is wrap it up in a custom method and run the result through the global format method to control how many decimal places and leading spaces the string has.
