Hi there!
I model playgrounds for work, and one of the repetitive tasks involved with this is creating fall zones. Essentially, these are outlined areas that are based on platform heights and sizes. For instance, a 1200mm high platform requires a 1500mm fall zone, which extends from all sides of the platform. An example is attached.
(This shows the fall zone around a set of chin-up bars).
The fall zone is dependant on the platform heights. For instance, anything between 600-1500mm needs a 1500mm wide fall zone. Once you go over 1500mm high, the fall zone increases proportionally, so a 2000mm high platform needs a 2300mm fall zone, a 2500mm tall platform needs a 3000mm fall zone, etc.
Is there any way to create a plugin that will automatically generate a fall zone in a design? Or at least reduce some of the steps involved in drawing a fall zone? (Currently, I draw a rectangle over everything, then outline the platforms, then use the offset tool to extend out the fall zone). I’ve never used Ruby before, so I just want to know if it’s possible before I dedicate any significant time to working on this.
Thanks so much for your help!
