Space between joists/studs is given in inches (16 or 24) in HB without possibilities to specify decimals, or meters, when the exact spacing CC should be 60 cm (0,6 meters). Anyone??
I think Housebuilder has a separate metric version.
Anssi
There are Imperial and Metric versions.
These have also be adjusted to suit newer versions of SketchUp.
This post by me links to the very latest versions of the two HouseBuilder RBZ downloads
http://sketchucation.com/forums/viewtopic.php?p=564448#p564448
Updated the two .rb files and extended c:\programfiles.… to iclude the .txt-file, and it all worked.
Thank you for very usefull help.
