Hi! How can I scale a dynamic object? I did scale visible in component attribute and nothing happened.
Perhaps the component author has removed the possibility of using the Scale tool on the component.
so, there is no solution in such cases?
Since you have SU Pro, you should be able to update the DC yourself, if you can get it saved back to your version.
Or upload a copy here, and someone can look at it for you.
A component author can “hardwire” a component in two ways: either by setting the lenx, leny, lenz values of all parts inside to fixed numeric values, or by disabling select or all Scale tool grips. These tricks can be located in the Component Attributes window. Normal interaction with a DC uses the Component Options window.
