Help: Floorplan is on two different levels
Hello! I’m trying to design a floorplan, and somehow two floorplans ended up on different planes. I’m not sure how this happened. I’m trying to get my build back on the same level. Can someone help? I’m really struggling.
Hello,
Was it already like this when you imported it ?
Sometimes in AutoCAD people mistakenly draw snapping to added blocs, or survey plans that are in 3D and you end up with lines that have different Z value
To fix it simply edit your group/component, select everything which is high above and move it down to zero.
You can also install thomthom’s architect tools that has a flatten function, select all geometry and use it, it’ll automatically make your plan 2D again
Oh this is amazing! I’m starting to do it now. It did come this way and I’ve been trying to figure out what to do. The fix is pretty simple but because of the different components a bit annoying. Thank you so much!!
