I am new to sketchup. I want to do a heat map for 3d model. I did this in autocad by meshing the solids/ faces and colouring the mesh. I wonder how can i generate a mesh on the face and then colour them in sketchup ? Is it possible to create mesh in sketchup using ruby api ? Is there any sample ruby code for this.
Yes.You basically create a Ruby script and put it in the plugins folder. In order to properly encapsulate your code from others, you need to follow a basic outline. I use this one (jimhami42_test_file.rb) for my quick and dirty stuff:
require 'sketchup.rb'
module JimHami42
module TestFile
# MAIN BODY -----------------------------------------------------------------------------
class << self
def start_test()
# Insert code here
UI.messagebox('Hello, World!', MB_OK)
end
end
file = __FILE__
unless file_loaded?( file )
menu = UI.menu("PlugIns").add_item("Test file") { start_test() }
file_loaded( file )
end
end
end
As you may already know, both module names need to start with a capital letter.
If you are looking for a 2D display, you can create a unit square face and make it a component. Duplicating this across rows and columns with unique component names will give you a grid. You will need to keep track of the component names and use them to apply the texture (or color).
More simply, you can create the unit faces as you go along and color them as you go. This is probably a lot easier than the above approach.
You can also create something called a “polygon mesh” that is an ordered collection of points, but I don’t believe it would be useful for what you’re trying to accomplish.
I created a simple piece of sample code that produces this:
In order to apply the colors to the faces, a different material is required for each. In this example, 400 new textures were added to the model to only give a 20 x 20 array. I initially created the squares as raw geometry, but it seems more efficient to isolate them in separate groups.
module JimHami42
module TestFile
@@model = Sketchup.active_model
class << self
def create_square(x,y,w,r,g,b)
group = @@model.entities.add_group
face = group.entities.add_face([x,y,0],[x+w,y,0],[x+w,y+w,0],[x,y+w,0],[x,y,0])
face.reverse!
face.material = b * 65536 + g * 256 + r
end
def start_test()
for y in 0...20
for x in 0...20
create_square(x,y,1,x * 10 + 20,y * 10 + 20,0)
end
end
end
end
file = __FILE__
file_loaded( file )
end
end
end
In a nutshell. As long as the number of colors is limited, you can do it quite easily. For more complex cases you probably need to generate the heat map outside SketchUp and apply it as a texture.
