Has anyone here used the Lamello Cabineo 12 fitting in their projects? If so, does anyone know where I can find a clean 2D DXF file of this fitting?
PRO_CAD_BEARB_Bearb-Cabineo-Abdeckk-flaechenb-V1-2-Gegenbohr-D5x12mm_#SALL_#ADWG_#V1.dwg (52.0 KB)
The DXF from Lamello’s CAD Connector is not the same file I posted. If you look on Lamello’s website under Processing for the exact filename I provided this one comes this one is Smaller is not to scale.
PRO_CAD_BEARB_Bearb-Cabineo-Abdeckk-flaechenb-V1-2-Gegenbohr-D5x12mm_#SALL_#ADWG_#V1.dwg you’ll see the file I have. Lamello supplies several Cabineo variants (different depths and fitting types); the only variant I want is the specific file named above. The file that I provided is to scale.
I have them like this, but every time I upload this into cab software, I get broken vector lines in long strings attached
Upload the file I provided, or download the one from their website under “Processing” with the same name. Import it as millimetres that version is to scale. If you instead use the one listed under “Cab Connectors” and import it as millimetres, it won’t match for some reason, that DXF file comes in much smaller.
My entire project is based on these fittings, so I don’t want to risk resizing them and throwing off the scale. I’d prefer to use the one that’s already to scale since my whole model was built around it.
Using the file I provided, how can I get clean vector lines and smooth curves in CAB software? Every time I export. it, the geometry appears as broken segments instead of continuous lines.Every time I export this as a DXF it never seems to come out right?
Didn’t we solve this back in July of 2024?
Edit: oh, never mind:
Good luck!
What has changed? Thanks for proving my point.
