Grading Plan- Proposed Grade Questions
I have a staff meeting at 1:30 that should take an hour so I would be available at 2:30 central time.
I’m on the west coast. I get off work around 3-3:30 (5 your time). Is that too late for you? I want to make sure your time isn’t inconvenienced.
I deleted some lines that were far from the contour lines, and deleted some tags that were lines that weren’t part of the contour lines that caused the creation of weird geometry using sandbox.
First I used sandbox to create the mesh but I didn’t like the result so I used topo shaper, a plugin from Fredo, after having the terrain generated I used another plugin from fredo called color by altitude which is part of fredo tools, I chose from dark green to yellow colors for the gradient and activated the option to generate contours lines with the same separation of the original ones.
I shared the file so you can download and check it if you want
Im am usually in the commute home at that time but can do it then, might help to avoid the traffic.
I sent you a private message :slight_smile:
I do tutoring for Sketchup here at meet.artisantony.com where I can screen share drawings. It’s real time, in SketchUp lessons. I don’t mind giving you a couple of hours for free to help you with your project. The main website is atdrafting.com. I guess we are not suppose to advertise here so the admin can zap this post if that is true :slight_smile: Just trying to help.
I’m going to contact you through your site. :slight_smile: Thank you!
I found tutorial by Eric very useful
