How can I selectively change the font color (e.g., dimensions) in 2016 Make?
I’m not sure if it is the same for Pro but this is where I change it.
Window > Model Info > Text
Thanks. I just tried that and it is the same in Make.
Glad I could help.
Hello Forrest!
If you want to make that change permanent going forward, open a new SketchUp file, make the changes (also in Dimensions) and then use File>save as template. Make sure you set your new template to be the default.
