FollowMe 2026
MAJ FollowMe – Smart Profile & Material Control for Follow Me
In standard Follow Me workflows, users face two major problems:
  1. Selecting and managing profiles
  2. Finding and assigning the correct material to those profiles
A common workaround is loading many profiles into the model and manually applying materials one by one until the desired result is found. This process is slow, messy, and inefficient.
MAJ FollowMe solves both problems.
The extension provides a dedicated profile list. Using the Left and Right arrow keys, you can instantly cycle through available profiles—fast, clean, and without cluttering your model.
Once the right profile is selected, you can switch its material just as easily using the Up and Down arrow keys. Materials can be added to or removed from the list at any time, giving you full control over the result.
Adding Profiles
To add a profile, simply click Pick Profile.
  • The first click selects the profile geometry
  • The second and third clicks define the reference point and direction
By pressing and holding the ALT key, you can select multiple profiles in a single operation. As long as ALT is held down, profiles will continue to be added to the list.
Profiles may contain holes and complex geometry, and the list supports multiple profiles at once. This allows you to draw several profiles simultaneously—up to highly complex assemblies, even entire buildings—in a single operation.
MAJ FollowMe turns profile and material selection from a trial-and-error process into a precise, fast, and professional workflow.
The Free Plugin:
MAJ FollowMe YouTube video.
Please follow me in YouTube
Greetings,
To my surprise – perhaps I’m missing something – this plugin, which I purchased and which wasn’t exactly cheap, doesn’t have a feature (like Profile Builder, for example) that automatically creates a profile by clicking on a path.
For example, I select a profile and then click on a path to specify the direction and extent of the profile.
Is the absence of this feature intentional, or am I missing something?
Thank you for your reply
Hi,Thank you for your support.
Feature Update: Smart Path Navigation
While this plugin does not include a “follow mouse” feature, it offers a streamlined Path Following system designed for precision and ease of use.
How it works: By simply pressing and holding the ALT key, the plugin will automatically select the next point along your defined path.
This manual-override approach keeps the workflow functional and simple, allowing you to progress through complex paths at your own pace without the unpredictability of automatic mouse tracking.
Best regards,
Majid
Hello, thank you for your feedback.
Yes, I have used the ALT key, but it’s very awkward when dealing with long arcs or curves, especially those with many segments.
It’s easy to stray from the path.
I don’t think this is the intended behaviour.
Profile Builder has no issues with this function and works almost instantly.
I thought your plugin would work similarly and… perhaps even better.
PS
If I understand correctly, is there no way, for example, to select a space frame (lines) and apply globally the functions of your plugin?
Only ALT key. MAJ FollowMe design for a free movment. Simply you can jump from an object to another. For example you can use ALT key and follow a line till middle then jump to edge of a 3D object.
Hi everyone,
MAJ FollowMe 2027 is now available!
If you use Follow Me in SketchUp, you know the two slow parts: managing profiles, and finding and assigning the right material. MAJ FollowMe solves both.
What it does
  • Unlimited profiles, unlimited materials — keep a huge profile and material library, loaded only at the moment of use, so your model stays light with zero bloat.
  • Instant switching — Left/Right arrows cycle through profiles, Up/Down arrows cycle through materials. Preview hundreds of materials in seconds and see the result immediately.
  • Profiles with holes and complex geometry, several profiles at once — even whole assemblies in a single operation.
  • Rotate Mode — lathed shapes of all kinds, including square and triangular cross-sections.
  • Multi-Face (paid version) — draw several faces with their materials at once. Save materials as a group and pick from them with a single Multi-Face.
  • Works with SketchUp 2013–2027, in English, Chinese, French, German, Spanish and Italian.
See it in action:
Get it
Upgrading from an older version? Please uninstall the old version first, close SketchUp completely, reopen it, and then install the new .rbz — installing over the old version does not work.
Frequently asked questions
  • Does it work with SketchUp 2025? Yes — the 2027 version supports SketchUp 2013 to 2027.
  • What is the difference between the free and paid versions? The free version lets you try the core profile and material workflow. The paid version ($40) adds unlimited profiles and materials, Rotate Mode and Multi-Face.
  • Can it create a profile automatically by clicking a path, like Profile Builder? No — FollowMe is designed for free movement. Hold the ALT key to follow a path point by point, and you can jump from one object to another.
Questions and feedback are welcome here — I will answer in this thread.
Best regards,
Majid
Greetings,
I have just bought and installed the extension following the instructions, with the following result (I must admit I am extremely disappointed – please could you provide information on how to get a refund for this purchase) - Draw Profile and Pick Profile results:
Did you add the license? Did you quit and restart SketchUp to ensure that the extension loaded with the license information?
What version of SketchUp are you using? Please update and complete your forum profile.
Hi,
Please uninstall the plugin, restart Sketchup and install the new one. Please let me know the result.
Thank you for your replies.
The extension does not require activation. The full, paid version I purchased should work as a full version.
Of course, I followed the steps in the correct order.
Uninstalling the previous version
Restarting SketchUp.
Install version 2027
Restart SketchUp.
I’ve included the results in the images.
