Floor generator extension not working with SKP 24
Hi all
Since the new update to Sketchup 2024 the good old free Floor Generator (SDM Tools) extension stopped working properly. Is it just me or do you also have this issue? Which similar tools do u use? Splitator is not free and there is no trial (? maybe I already tried it once and didn’t like it enough to pay an abo for it, and while I’m all for developers earning what they deserve but to list something as free while it’s not is …just not right)
This plugin was withdrawn due to a copyright complaint in 2018. It is not surprising that a 10 year old plugin would fail to load with all the Ruby version changes that have happened over this time.
See the “official” notice at SketchUcation:
@sdmitch
Please start another topic on Splitator to discuss it. (You’ll help keep the forum tidy and get better replies when not firing multiple questions in diverse directions.)
And also take complaints on the Extension Warehouse to the correct forum category.
Yes I’ve just noticed that the floor generator plugin doesn’t work properly with SketchUp2024. The flooring that is generated doesn’t have any depth or gap.
Is there an alternative plugin? Seems like one of most important plugins to have if your doing architectural / interior modelling…
Hi Alex.
I am having the same issue.
Did you manage to find an alternative plugin?
I have the same problem. Has anyone found an alternative plugin?
im new here.
I’ve found the “Oob” plugin is a decent replacement however it is not free and not quite as good as floor generator but does the job.
Its probably best to keep an old version of SKP handy for the specific use cases.
Hello,
I’ve found the plugin “Face Array” which is free and made by Curic.
It doesn´t have the quality and the variation of Floor Generator… but can help :slight_smile:
Free plugins that can replace Floor generator: Curic Face Array (it’s pretty good), Custom Ground Wizard (like Floor but it’s not as diverse)
I tried to modify Floor generator and it works perfectly on Su 2025.
