last day worked sketch up file is mow cant to open , error says its fail to open
You must upload the file, so anyone can check what’s going on or Colin to recover in case it’s corrupted.
Your profile says you are using the Free Plan. Is that correct? If so, it would indicate you’re working with the web based version. Maybe a different browser would work.
Sharing your SketchUp file as requested will help us help you.
