Extra Surfaces When Closing Holes In 3D geometry
I got a model from the 3D warehouse (HTC Vive Controller by Andrew O).
I’m trying to clean it for a project I’m working on. When I try to close open holes they auto generate multiple surfaces in the same area.
Example:
3 sided triangle with all edges but no surface.
Draw a line on one of the edges.
5 surfaces generated inside the triangle.
How about uploading the SKP file so we can see what you’re seeing?
VIVE-Controller.skp (991.6 KB)
I’m hitting a similar issue in another topic. Pretty sure that he uploaded his STL version of the model, and those can have a lot of holes in them. They’re also all triangles, which SketchUp doesn’t need to be. If you download the STL version and import that into a new SketchUp file, with the model units set to meters, it hopefully won’t have any holes.
STL models seem to be insanely complex. I’m using CleanUp3 to try to make them more sane:
https://extensions.sketchup.com/en/content/cleanup³
Here’s what I mean by insanely complex.
I’ve been using Solid Inspector 2 to find the problem areas. But when I delete the extra surfaces and redraw a line, all the surfaces come back.
Looks ok here… I ran Edge Tools to close any edge gaps, then MakeFaces to close holes. Then CleanUp3 to remove and duplicate faces, etc. Still needed to hide a couple of stray edges manually. Kind of expected that some amount of clean up will be required with stuff from 3D Warehouse.
