Hi!
I’m new to SkatchUp. I have a problem to export the modle so my imges (jpg) will be visible in the 3ds files.
I have ad the images into sketchUp as images (jpg) – placed it and export 3D or even tried 2D (pdf). In the file it’s only a dark square visible where the images is placed.
This is probably not the correct way to do it, what is the correct way?
Please determine you graphics card and update the info in your profile. It seems possible this is an OpenGL issue. You could test this theory by turning off hardware acceleration in Preferences->OpenGL.
[quote=“Reboard, post:5, topic:23088, full:true”]
Thanks, this is a bit too technical… [/quote]
You should be able to look at your computer’s specs easily enough. Or maybe you can find someone to help you determine it.
[quote=“Reboard, post:5, topic:23088, full:true”]an other thing is that I have the TRIAL version of SketchUp Pro.
[/quote] It doesn’t matter that it’s the trial version of SketchUp pro.
Try the attached. When I exported a 3ds file and imported it into a new SKP file, it worked just fine.
