Export for CNC
So picked up the Sketchup Pro trial to see if I could export some subwoofer cabinets so that I could have a CNC shop cut them for me. But when I export to DWG or DXF and send those, the shops aren’t able to use them for whatever reason. Most then ask for “2D drawings”, even though I thought that is what a dxf or dwg drawing was. So clearly doing something wrong.
This is the cut sheet…both sides have dimensional cuts on them. Is there some option in the export that maybe I need to do but am not doing?
Should add, when I try to export, the full scale 1:1 option is greyed out and not selectable?
Ah, okay, I think I forgot to set the camera to parralel projection first. Wonder if that was the only issue.
You also need to select the appropriate standard view. Looks like the standard Top view would be appropriate.
For CNC Export - look no further then OpenCutList (the extension for Sketchup). It has an excellent 2D-DXF export option that can even give you “true arcs” - which is really important for parts of that size. There is a bit of a learning curve but it’s totally worth it.
Native SketchUp Pro can export true arcs and circles, make sure to set up your .dxf 3D export correctly.
Since you have machining on both sides, you’ll need to export two scenes to capture the geometry of both sides. As said, Parrel Projection and Standard Top view
Hmmm…didn’t realize that. Was trying out OpenCutlist and I don’t think that’s an option.
When you say export two scenes (does that mean two views, top and then bottom?), how does the CNC shop combine the two scenes?
Sketchup can export true arcs and circles (anything with a constant radius) not curves or exploded poly lines. Select an edge and check entity info, it should say circle or arc.
The method of export outlined above using a single plane of geometry viewed in planview/parallel projection and 3D export will yield a single 2D .dwg or .dxf file that shows the edges as real arcs calculated from their radius. This will be a 2D file, suitable for any sheet goods CAM manufacturing method, waterjet, CNC router, plasma cutter, laser, others with no Z information.
This method works for 2D files. There is no method for outputting true curves from SketchUp in 3D. If your shape is not “flat”, in that is has data or shape in 3 dimensions, you will not be able to output a format that the shop can plug directly into their software with curves. You will need to work with them to rebuild your object in their software.
It looks like your circle files are cut through, export them separately via the above method for a 2D file for the shop. The file with a routered chanell will need a different method. Dwg can be 3D or 2D. Export the routered file without curves as a 3D dwg but with all the geometry for a 3D file.
I’m on my phone but if you post your file here I’ll look later.
Thanks, sketchup file is here.
Dual AV15H horizontal cuts 2024Sketchup Pro.skb (583.5 KB)
Basically, yes. I would lay each piece down onto the XY plane side to be machined face up. Standard Top View, Parallel Projection.
Looking at your file: It is only the ‘Sides’ that have machining on both sides.
You will need to send them a dxf of both faces of the sides. You will also have to indicate to them the depth of the dados and that some edges have a round over.
Baffles, Screen, Internal Brace, and Top/Bottom are machined on one side, so you only need to send the dxf of side with machining. Again you will need to call out the depths of dados and holes that are not cut through.
I think it could be a very practical option though…
It can export all your part in one click without changing the projection view. And it can convert as true circles exploded or not exploded circles.
Exported from your SKP file :
I - Internal Baffle 2 - 1 of 1.dxf (8,6 Ko)
Thanks, but does it also preserve all dado depths/rounded corners, depths of holes, etc?
Depth in 2D DXF doesn’t really exist because everything is flat. But OpenCutList uses DXF layer name to embed cutting depth.
C - Bottom - 1 of 1.dxf (8,5 Ko)
Rounded corners can’t be exported in 2D…
Interesting. So no way to export something like this?
Also, I don’t seem to get the same top/bottom view selections in OpenCutlist, only these…
With top and bottom view, no.
How would you like to see it in 2D ?
Yes, other view will be added in the next release that is still under crowdfunding and development.
So the screen shot you showed above is not from a publicly available version?
I don’t know … not sure how CNC software show these sorts of cuts?
