Export certain attributes to notepad file
Hi,
I have draw a cabinet component. the cabinet exist out of 4 panels. Is there a way to export the text or values that i filled in at the component attributes to a txt-file (notepad) and save the txt file to a certain location at the computer.
Can somebody help me please, im newbie to ruby?
1. Before you get into a long steep learning cycle for Ruby coding, check if the built-in attribute reporting capabilities of Generate Report will give you the data you need …
P.S. - You can always convert the CSV (comma separated values) text file to a plain text tab separated list.
2. There are several extensions for creating custom reports from attribute data. Check those first before beginning a custom Ruby project.
Ok thank you very much i will take a closer look to it.
