Error in Sketchup
Can anyone help me i have the following error:
Error Loading File C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/CityGML/CityGML-loader.rb
Error: #<LoadError: 193: %1 is not a valid Win32 application. - C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/CityGML/Win32API.so>
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require’
C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/CityGML/CityGML-loader.rb:13:in `<top (required)>’
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `require’
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `load’
C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/CityGmlExtension.rb:14:in `register_extension’
C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/CityGmlExtension.rb:14:in `<top (required)>’
Error Loading File libxml.rb
Error: #<LoadError: 193: %1 is not a valid Win32 application. - C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/libxml_ruby.so>
C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/libxml.rb:10:in `<top (required)>’
Error Loading File xml.rb
C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/xml.rb:11:in `<top (required)>’
It indicates there’s a problem loading the extension CityGML. Do you have the most current version? Did you install it correctly? If you do have the current version and installed it correctly, you should contact the author and see if they’ve got some help for you.
The message also implies that there is a 32 bits related problem:
