ymag
April 6, 2023, 9:12am
1
Hi all,
I am using SketchUp customized with Ruby.
In your Ruby program,
options = {
:validate_dae => true,
:merge_coplanar_faces => true,
:show_summary => true
Sketchup.active_model.import(fileName, options)
and call.
I tried to read a .dae file with this code.
If this process is executed with SketchUp2023 for mac version(v23.0.396), it will end with an error.
It worked without problems in SketchUp2023/Win version.
In addition, It worked without problems in SketchUp2022/Mac or Win version.
If this .dae file is imported from SketchUp2023 Mac’s File menu,
it imports fine.
Is this a programming issue or an API issue?
Please let me know if anyone knows the solution.
Thank you very much.
export_out.dae (240.9 KB)
dezmo
April 6, 2023, 9:21am
2
Please try to post your code according to this:
Continuing the discussion from Ruby backtick returns nothing! :
Triple backtick delimiter lines.
What is a backquote ?
[image]
Backquote character key on US keyboard.
If it is error message text (or some other plain text that contains <, >, #, or other characters that can confuse Discourse markdown,) then specify “text” as a lexing language:
```text
paste error message here
If it is Ruby, then:
```ruby
# code here
If it is Javascript, then:
```javascript
/* js…
ymag:
What error?
ymag
April 6, 2023, 9:30am
4
Message is fail to import (in Japanese) by dialog.
Also, the function returns false.
ymag
April 6, 2023, 9:37am
5
The code is like below.
def import_dae()
filePath = "/tmp/export_out.dae"
options = {
res = Sketchup.active_model.import(filePath, options)
puts("import result=#{res}")
end
dezmo
April 6, 2023, 9:43am
6
I do not see problem with the code itself…The only thing I can suggest to define a full path for the filePath (?)
Unfortunately I can’t test - no experience - on Mac, the .dae file itself looks good too…
ymag
April 6, 2023, 10:05am
7
Additional Information
I had no problems with SketchUp2023/mac on my M1 MacBook Air.
An error occurs only with SketchUp2023/mac on Intel Mac mini.
Try changing some of the options …
def import_dae(caption = 'Import Collada (DAE)')
win = Sketchup.platform == :platform_win
ext =( win ? 'Collada Files|*.dae||' : '*.dae' )
file_path = UI.openpanel("#{caption} ...", Sketchup.temp_dir, ext)
return unless file_path
options = {
title = 'Import Options'
prompts = ['Validate Dae','Merge Coplanar Faces','Show Summary']
defaults = [
options[:validate_dae],
options[:merge_coplanar_faces],
options[:show_summary]
choices = Array.new(options.size, 'true|false')
opts = UI.inputbox(prompts, defaults, choices, title)
return unless opts
options[:validate_dae]= opts[0]
options[:merge_coplanar_faces]= opts[1]
options[:show_summary]= opts[2]
res = Sketchup.active_model.import(file_path, options)
puts("DAE import result: #{res}")
end
NOTE: The DAE import summary dialog is not working correctly.
It flashes on the screen so fast it cannot be read.
ymag
April 7, 2023, 3:09am
9
I did a test.
The following combinations are executed, and “Import failed” is displayed for all.
the meaning of the number
(1) Validate Dae, (2) Merge Coplanar, (3) Show Summary
and
test combination
(1) true, (2) true, (3) true => fail
(1) false, (2) true, (3) true => fail
(1) true, (2) false, (3) true => fail
(1) true, (2) true, (3) false => fail
(1) false, (2) false, (3) true => fail
(1) true, (2) false, (3) false => fail
(1) false, (2) true, (3) false => fail
(1) false, (2) false, (3) false => fail
thank you.
Okay please file a API issue in the tracker . Be sure to note the version and that it’s a Mac Intel only issue.
ymag
April 8, 2023, 2:12am
11
I got it
I will apply for a tracker.
thank you.
