Error in "Back Edges"
Hello. I have just installed SU PRO 2021 and noiticed that the dashed lines in the Back Edges do not work als they are not dashed.
Is this a little Bug?
Hello, it works fine to me ! can you post a screenshot, preferably with your style panel or toolbar shown ?
Hi Paul,
Thanks for your swift reply. Please find enclose a zoomed in screen print and an overviewed screen print as well as the original SU file. I did import a DWG zo perhaps this might have something to do with the issue?
10187-20S1.skp (793 KB)
And as Paul said, it will be easier for you if you keep the raw geometry (line, arc, face) as Untagged.
it is not a bug, it is due to your tag management. Since version 2019 we have the possibility of making dashed lines in the tag panel. your model has differents tags and some of them “force” the linetype to be continuous, which leads the back edge style not to show them dashed.
You should manage your models differently, as only groups or components should be spread on tags (not the raw geometry and edges)
Thanks Paul
