I click on the Environment picture but it does not show up on the screen. I haven’t used for long time and forgot a setting to be able to see the environment as part of the drawing.
Thank you!!
Thank you!!
Your profile says you are using SketchUp 2025. Is that right?
Environments in SketchUp 2026 will show if you select the In Model one, click on Edit, and make sure Use Environment as Skydome is ticked.
You also need to have the new graphics engine selected. If you are using the Classic graphics engine the environments won’t be available.
Thank you Dave. It was the new graphic engine not selected.
