Enlarge an object
Hello I have a prob… simple question.
How to enlarge an object without measuremant changes.51017.skp (460.6 KB)
Zoom in.
Hi @abniezenster.
I’m afraid you need to be a little bit more specific about what you really need, if you only want to enlarge and object and keep the rest of dimensions then take a look at this extension:
https://extensions.sketchup.com/en/content/fredoscale
Regards.
Dave
I think the drawing is not recieved. So again.
Only the spoke bigger without changing the size values. Or do I have to change the values back after scaling?
Albert51017.skp (467.7 KB)
I saw the draw, but I don’t understand the question.
Spawn
Make ONLY the spoke bigger with scaling the values rises. With zoom the hole drawing comes bigger.
Is it possible to scale without changing the values?
albert
You’re not giving anything to go on. what do you want to do?
Something like this?
Wheel
NO, It"s clear what you doing I onderstand. But take that spoke at the side with the mesurement and do the same.
The component to the side is unrelated to the ones in the wheel.
You need to make your request more understandable. What I have read is that you want to make it larger without changing its dimensions. You can’t make something larger without changing its dimensions. If that was possible, you’d be able to wear the same clothes you wore when you were only a year old.
Dave
510171.skp (438.9 KB)
I thought it was possible. I obtain my goal in an other way.
Scaling the wheel small and ZOOM the draw.
Thanks for your help.
Albert
Box
you were right! But first scaling other oject (wheel) smaller.
Thanks
Albert
