Here is link to old DC stair plugins by Howard Lesile; DC StairCaseBuilder • sketchUcation • 1;
do a search in the forms ( Including Sketchucation) there are some by others also.
I looked at this DC because I would like to make use of a good dynamic stair component, but I could not get it to change in any way. The bounding box is yellow and it’s impossible to see the grip handles when attempting to use the scale tool on it. How do you change the color of the bounding box to blue like the other DC’s that I have used before?
I’ve just been developing my first DC, and have made a simple straight stair, which (as far as I’ve tested it) seems to work ok.
See if it suits you.
V new to this forum, so not sure if I can attach a SU file - I will if I can, if not, I’ll add it to the 3D Warehouse and get back to you here with a link.
A few minutes later - sorry, don’t see how either to insert or attach a file.
May I ask why you need to use a DC rather than two (or however many) separate stair components? You could make a standard tread/riser module and a few other standard details and then just crank out staircases to order on demand pretty easily. Just curious, because, for my personal use, I haven’t really been able to justify the added effort a DC takes over just modeling what I need, reusing existing geometry whenever possible.
I gave you link you should read and learn before using.
Here is another that may help you. [Plugin] Stair Maker • sketchUcation • 1. For straight I just use a story pole to lay out and since each locale may have different code requirements they cannot not cover all cases as Lesile pointed out in his link.
IMHO before you can evaluate if one is good or bad you need know the basics your self.
Lesile’s model has a large input table you have to fill out and has nothing to do with grips, sounds like you were referring to a component and not dynamic component. IMHO you need to read help about DC and learn how to use them.
Here is link to simple search that should help you dynamic components sketchup - Google Search
I really appreciate the information. I thought it would be good to explore the use of dynamic components and I still may do that but I think @Gully and @Geo are right. I have become fairly proficient at modeling specific components as needed including stairs, so I am going to continue doing it that way and be satisfied with making modifications to components when necessary.
I wouldn’t be alive if I lived in a place like that. Architectural magazines are also full of houses that have stairs without railings. I always hope that they were removed just for the photograph.
To answer your earlier question: Lesile’s DC is a skip file ( component) =>copy into your model , context select, select DC component, select DC instance and the input table then opens to input design parameters. It is old 2010 and I was concerned about using in 2015 because of 2014 API changes but did not see any ruby counsel errors when opening.
