Dynamic Components with Conditional Rotation
Because I got an ERROR on my previous Topic…I’ll repeat it here:
I hope you PRO GUYZ can solve the following issue:
Attachment more or less speaks for itself. I want Component B to rotate 90 degrees as soon as Component A has a ValueZ of zero. I’m almost sure there’s a way… but somehow I don’t seem to get the function coding right.
Anyone of you who can…? Looking forward to your solution(s).
Kind regards,
Rob
are they part of the same parent component? if so, looking at the Z position value of A and then using that set the Z axis rotation of B should work. if they’re not part of the same component, then likely you need some scripting.
They are both part of same parent component. After some random alternatives I finaly got it working. Script for Component A as follows:
Behaviors - onClick - animate(Z,20,0);animate(“B!rotz”,0,result_X)
Custom - result_X - =if(Z=0,0,90)
Thanks for trying to help…!
Rob
You can have children (DCs) reference each other in a file, moreover this file can act as a parent, thus can hold global attributes, which fill inserted DCs
