Hello,
This is pretty simple and someone has probably already done this, but I am looking for help on creating a custom attribute on a dynamic component. The component is just a simple path (multiple edges) and all I’m trying to do is report the path length.
I know entity info already provides this when you select the line but how can you get this info to report as a custom attribute if you make a path a dynamic component. Ultimately my goal is to generate a report with the path length of components. It’s easy to calculate a single edge length using LenX, LenY, LenZ, but how do you accomplish this for multiple connected edges?
Thanks for any help on this,
Chris
There are no built-in iterator functions for the Dynamic Components.
So for example there is no EACHEDGES()
function that allows iterating a DC’s edges, nor any EDGELENGTHS()
function to sum the ungrouped edge lengths. (Strange as there is a FACEAREA()
function to sum ungrouped face areas.)
I do not know if it is yet ultimately possible, but just brainstorming…
Each “segment” would likely need to be a dynamic sub-component, that has an edge, and a nested DC segment.
The outermost “ancestor” DC would need attribute:
Segments
as the number of segments in the path.
TotalLength
as the total cumulative length.
Each “segment’s” instance “dynamic_attributes” dictionary has:
Index
as it’s segment number in the set of Parent!Segments
X
,Y
,Z
is the “segment’s” origin (in relation to the outer parent DC’s origin.)
RotY
& RotZ
is the direction pointing toward the next copy’s origin.
LenX
the length of the “segment”.
Each segment could reference it parent length via =Parent!LenX
and set a cumulative path length into a local (instance) attribute like:
PathLen: =LenX+Parent!LenX
Now if the last nested segment does not have a inner child segment perhaps it might be able to pass the cumulative length up to the outermost “ancestor” segment, if you know it’s name. (Let’s call it “OuterMost”), ie:
=SET("OuterMost!TotalLength",PathLen)
But I am unsure if you can set another component’s attribute this way, or if you can skip up multiple levels.
