Hi there,
My client has a few hundred Autodesk Inventor models that they’ve exported to .dwg files. Upon importing them to SU, all edges that have a fillet applied have a ton of lines on them. If I go to hide/smooth these lines, they end up deleting the surface and you can see the inside of the model.
When I save a file (for example a simple outdoor table with three pieces) it saves at about 300KB. The competitors equivalent is about 20KB.
So I’m asking, is there an efficient way to import .dwg and save as a SU file that is extremely small in size, or should all these models just be re-drawn in SU? I’ve tried a few plug-ins (Clean-Up3, Polyreduce) with no results.
Thanks for any help!
