hi, the display window has stopped showing complete information. it’s cut back information down to two things.
I’m using sketch go.
did I turn something off or on.
any information will be appreciated.
Many settings have been moved to the Style tab.
ah ok thanks . I found it.
to bad it was simpler where it was.
all good thanks again.
You can always use the search function to find them directly and set keyboard shortcuts if you want.
Thanks very much.
That’s another topic for another day.
I’ve never been able to set up the custom keyboard functions.
I had Sketchup pro for a couple years.
But I found i didn’t use it to it’s full potential as in a carpenter that build very simple buildings
I used a 3D mouse with the pro version.
Now with Sketchup Go , I can no longer use the mouse
Thanks again for your help.
Do you have your browser set up to delete all cookies when you close? I think for the web versions the shortcuts are stored in a cookie.
Thanks @kahnawakewoodcrafts for your post and feedback. As @Box said, the SketchUp for Web editor with a subscription has these View options in the Styles panel (they’ve actually always been there; for a time they were in both the Display panel and the Styles panel). This was mentioned in this other thread.
SketchUp for Web does support a 3DConnexion 3D mouse. If you’re running into an issue with that mouse, make sure that you have the latest 3DXware drivers from 3DConnexion.
Like @Box said, you set keyboard shortcuts in SketchUp for Web through the search (aka Omnibar)
thanks very much for this answer . I’m absolutely gonna try it.
thanks again.
Sorry for the super late response. life gets in the way sometimes.
thanks again
This topic was automatically closed after 186 days. New replies are no longer allowed.
