Dining chair designed by Danish furniture maker Tage Frid.
This was done as a demonstration for a student. Interesting project because the only things on-axis in the model are the long edges of the front and rear seat rails and the stretcher between the front legs.
As for comfort, I donāt know. You can find examples of this chair for sale. I think it was designed at a time when people didnāt lounge around the table after dinner so the chairs didnāt need to be so comfortable. I expect it would be adequate, though.
Yes he was. I met him in the early 70s when I was taking a woodworking class in fine art school. During his presentation he hand cut some dovetails for us. We were all amazed that he could cut the joint while carrying on a conversation with us. He finished paring the last pin and put the two pieces together. Then he look up and scanned around the room as if he was looking for something. The professor asked him what he needed and he said, āDovetail hammer.ā None of us, including the professor, had ever heard of a dovetail hammer before. Then Fridās eyes lit up. He walked over to the tool wall and grabbed a claw hammer. He went back over to the bench, beat on the end of one of the pins in his joint, then held up the hammer and with a big grin, said, āDovetail hammer!ā
The common approach when cutting dovetails is to leave the pins slightly proud so they can be planed off flush with the adjoining piece. That also allows you to whack at the pin without damaging the surrounding wood. Beating on the pin with the hammer spread out the fibers of the pin to fill an inadvertent gap in the joint.
Iām currently trying to build this chair. Unfortunately Tageās book isnāt clear on certain aspects of this chair. For instance, if the legs inner taper all the way to the side aprons, or if the taper begins after the stretcher, or how the are the legs supposed to be shaped to match the taper of the side aprons front to back.
Itās been a long time since I modeled the chair and I donāt have the references to hand but as I remember the tapers on the inside run all the way up to the shoulder of the tenon on the top of the leg.
