I’ve been using sketchup 8 for a long time. I just got started on 2015 and it seems that the dimension tool has been changed a bit. Instead of letting you grab just any intersection of two lines, it grabs the entire line or shape. This is seems to be making some explicit measurements a lot more difficult.
For example, I’ve made a simple cylinder by extruding a circle. When using the dimension tool to measure the cylinder’s height, the tool locks onto the circular edge of the the top surface instead of grabbing a point on the edge of the circle like it would have done in sketchup 8. How can I measure from a point on the edge of the circle to a point on the opposite circle without doing one of the following:
Drawing a line between the two points you’d like to measure, then dimension that.
Grab the edge of a cylinder (the hidden geometry of the curved surface).
H appears to be the Hand tool in my setup, that’s an easy fix. I figured that exploding would work. I’ve also found that drawing a short line from a point on the circle will allow me to grab that point quite easily.
I appreciate your help on this.
Completely off topic: Is there an extension or simple tool that you have allows you to make the gif instruction that you used in your first response?
