Apple M1 Tahoe 26.7.1, Layout 26.2.242
When I resize my window/ viewport in layout it shifts my dims. Is this a known issue or does anyone else have this issue?
Yes. This is a known issue but it’s supposed to be fixed in the next release whenever that is.
Please update your forum profile.
Thanks for the reply.
Updated
There is a work around. Size your viewport to a point where you can access all of the anchor points you need, dimension the drawing, draw a rectangle around the part you want to remain visible, select both the drawing and the rectangle, right click and select create clipping mask, modify stroke/line weight of rectangle frame if you so desire. To remove the mask, right click and select release clipping mask.
