Define the width of a inputbox
hello,
is there any way to define the width of the standard inputbox via ruby?
i have some longer expressions and they are not shown in whole length in the input fields.
thanx
stan
The .UI.inputbox(*args) ⇒ Array, false
aim is to create a simple dialog box for inputting user information, but unfortunately you do not have so much influence how it will look like. It have its own limitation and - as you discovered some small bugs…
You have to use the HtmlDialog class that allows you to create “much better” dialog boxes…
One of the bugs is that the width of the inputs are set to the widest of the prompts.
hi dan,
thanx for that info . problem easily solved :slight_smile:
extra array of prompts for the menue with a longer empty string added :slight_smile:
and voila :slight_smile:
regards
stan
Yeah, it’ not ideal, but it is a workaround.
We have a boiler plate example for an inputbox replacement that’s a good start: GitHub - SketchUp/htmldialog-inputbox: UI::HtmlDialog example recreating UI.inputbox functionality in the SketchUp Ruby API
hello, after a longer period i am back in the ruby project. thanx a lot, i saw the github example, but i must confess…i am confused, how to use it. i understand, that i need a rb, js and html files .
is there somewhere an example to download, which generates an inputbox with some lines for numerical or string input, i could download, study and modify? (just to understand , how ruby calls the js, which shows in html and how it sends the data back).
i only need a simple pendant to the old inputbox, only for the scrolling option (when too many parameters have to be desplayed.
thanx a lot
stan
For example, you can check “Examples and Tutorials” section in:
The are simple examples in the GitHub repository’s README doc:
htmldialog-inputbox/README.md at main · SketchUp/htmldialog-inputbox · GitHub
The whole point of that HtmlUI library is that you do not need to understand how the Ruby ↔ JS communication works.
You just use it as described.
hi dan,
a big mountain, i start…
thanx fpr the links :slight_smile:
stan
