Is there a way to use/place a switch or checkbox as an attribute in the Component Options Window?
I use for now a list item with “Yes / No”. But I’am more attracted to a Switch.
A second question, Is there a way that I can let the user enter a value f.e a number between 215 and 270?
To create a list with all those number is not very handy.
A thirth question. Am using Concatunate but it doesn’t work wel.
F.e =CONCATENATE(“Type a value between 215 and”, P2_PlafondHoogte)
Gives me
Sorry, no. Checkboxes are not yet implemented for the Component Options dialog.
This would need the support of a boolean type for custom attributes (Some of the predefined attributes or behaviors are boolean, but this is not yet implemented for custom attributes.)
Not tested but I wonder if a nested IF function will work ? @pcmoor ?
Try one of these … =CONCATENATE("Type a value between 215 and", CURRENT("P2_PlafondHoogte"))
… or … =CONCATENATE("Type a value between 215 and", REPLACE(P2_PlafondHoogte,1,0,""))
… or … =CONCATENATE("Type a value between 215 and", REPLACE(CURRENT("P2_PlafondHoogte"),1,0,""))
Ie, they never implemented a TEXT() function, but the REPLACE() function converts the 1st and last arguments to String.
Yes that works,a similar expression
=largest(215,smallest(“AttrName”,270))
Note, current is required if using the dimensional or position attributes of the parent, which returns inches, therefore for metric multiple the result by 2.54
with regards the concatenate, place a space after the first bracket (“parentheses” to change to CONCATENATE( “Type,
its a bug that fixes itself once working you can remove the space if you want to
I use now the IF function and one line above a text field with just dynamic info ( like the thirt question )
The problem with my formula raised when the P2_PlafondHoogte value was not yet used bij the DC options dialog. The P2_PlafondHoogte value did has to be a ‘=value’
But that means that the P2_PlafondHoogte value has to be explicit a value to begin with, and that was not meant to be.
Is it posable to create a kind of options block which is possible to get hidden? Feature request!?
Some items that at least for me are welcome ( actualy I need them ).
My Feature Request voor DC’s in SU.
