I think it’s just that DCs are themselves confusing, and some of the coding seems a bit flaky.
I found much the same.
The thing that helps (but doesn’t solve the issues fully) is to remember that Sketchup’s native unit is the inch, with floating point representation down to about 1/1000th of an inch. All values for lengths, for example, are stored in inches internally, and only converted from other units on input, or output for display in other units.
Wherever units aren’t explicitly specified, SU assumes inches. (And sometimes even when they are, I sometimes think!).
And it still gets extremely confused sometimes.
So if you need to display the value of Hem, you will need to multiply its internal value by 2.54 to get mm where you want it to display in mm, or be used in arithmetic with other dimensions in mm.
It isn’t the same in a DC, but if you are working in any metric unit (mm, cm, metre) and try to enter a value in the measurement box, SU makes a complete pigs ear of a mixture of feet, inches, and fractions. It’s been accepted as a bug.
See this thread. SU doesn't recognise fractional inches (e.g., 1/2") as an imperial measurement when units are mm
