DBS - Pipeline from edges
Check my newest version of the pipline extenstion.
It creates a pipeline with bent corners on selected edges.
Key features:
  • object type: pipe / wire
  • every model unit
  • pipe diameter: Outer / Inner
  • bend pipeline corners with a set radius
  • select material list from Model
  • check maximum possible bending radius for selected edges
  • pipe roundness / segmentation parameter
  • bending segmentation parameter
  • option to hide selected edges after the pipeline is created
  • option to draw the middle line
  • place pipeline dimensions with length by using standard Tools → Text
Works also with SketchUp 2017 Make
version: 1.7
Youtube:
version: 1.6
Check more here:
:point_right: SketchUp bend pipe extension
Check short tutorial that helps make holes in the pipe with solid tools operations.
Hi,
I recently added an article on my site showing possible ways of making curved pipe (pipeline).
You can see there how you can do that with native tools or using this Pipeline from edges extension.
